Author Topic: Need a Valve Shim  (Read 1157 times)
Need a Valve Shim
« on: January 04, 2011, 07:43:54 pm »
I decided to check valve clearances since my R6 is apart.  15 of the valve clearances were good...and one is just out of the tight end of the spec. :11
So I had to remove the exhaust cam for ONE shim!  Anyway, does anyone have a 180 shim I can buy or exchange?  It is the 7mm dia type.  I have a few different sizes if you want to exchange.  I have several 170's and 172's and a 184.  I also have two larger diameter ones that came out of a TL1000 but I can't read the sizes.  One is a 2_5 and the other is a 2_8, but I can't read the middle numbers.
Re: Need a Valve Shim
« Reply #1 on: January 04, 2011, 07:49:02 pm »
Have you checked with brian? kpsr? I sure he would have one.
Offline kpsr
« Reply #2 on: January 04, 2011, 08:11:52 pm »
I have the shims you need. I can also custom grind to the thickness you need. Give me a call and swing by the shop tomorrow.
