Author Topic: z1000 636 swap  (Read 20994 times)
z1000 636 swap
« on: August 19, 2012, 06:59:47 am »
Alright guys found out last night about the lower triple shaft. You can press the Z's out and press it into a 05 636 lower triple for sure. This is one of the things me and curt didn't know and could not find any info on. So now if you want to run the 636 triples you can and should not have any issues with the spanner nuts. I have seen several forums with post that say they just used the 636 triples up  and lower but were only able to install one nut. ( ummm... that is a little scary). Keep everyone updated if when find anything.g else that hasn't been tried. :21
Re: Re: z1000 636 swap
« Reply #1 on: August 19, 2012, 07:17:09 am »
Nice find, so can you just put the 636 forks into the Z triples? Our or do you have to swap the whole front?
Sent from Cygnus X-1
« Reply #2 on: August 19, 2012, 08:02:24 am »
You can just bolt the 636 forks right up without having to do that. But if you find your self in his situation with a bad triple tgen its a lot easier to find the zx10 or 636. And a lot cheaper!
Re: z1000 636 swap
« Reply #3 on: August 19, 2012, 09:23:13 am »
About a hundred bucks cheaper. Also loose about a pound off the forks
« Reply #4 on: August 19, 2012, 09:34:38 am »
AhhhhI see, forgot about having the bad tree
« Reply #5 on: August 19, 2012, 09:39:14 am »
I'm super excited to make that transformation, after results I got from the rear swap it's like having 2 bikes in one;D
Re: z1000 636 swap
« Reply #6 on: August 19, 2012, 11:11:12 am »
It was going to just do the fronts till I found a rear on eBay for 50 shipped.
« Reply #7 on: August 19, 2012, 11:19:53 am »
Cool, now I have fork envy:o
Re: z1000 636 swap
« Reply #8 on: August 19, 2012, 01:10:28 pm »
 :34
Re: z1000 636 swap
« Reply #9 on: August 21, 2012, 06:28:19 am »
Well got bad news.went to install the lower triple with my upper z triple. Can't be done. The z has less of a sweep back on them so the forks want slide up.have to use the 636 top and lower together. Doing this though there are a few things that want work. Your ignition will not lock. Shitty!! You will have to run clip ons only one bolt for the bottom bracket for the fairings will be able to be used. Also will have to make one for the top to bolt and it will only be one as well., that's where I've got so far will post pics later.
« Reply #10 on: August 21, 2012, 07:47:42 am »
Good to know, I'm sure you guys are gonna get it right, can't wait to see it
Re: z1000 636 swap
« Reply #11 on: August 21, 2012, 08:37:11 am »
Yeah me too. Just a pain. I ended up taken the lower out n putting the other one in about 4 times last night trying different things. Oh well.
« Reply #12 on: August 21, 2012, 08:44:33 am »
Dang it. I will be up late tonight so I can help out a bit. That the thing with trying out things like this. No instructions, just have a trail and error. Hopefully we will be able to use the clip ons in a so.e what normal position for you.
« Reply #13 on: August 21, 2012, 09:21:32 am »
Hell might as well go ahead and fix em up stunt style, add a rear handbrake ;D haha
Re: z1000 636 swap
« Reply #14 on: August 21, 2012, 10:05:57 am »
Yep. I already slid the clip ons  up. Was able to get the bracket bolted to the bottom triple but since there's only one hole I only have one. Think I can make a little bracket for top to bolt using the 636 wire guide that was on it with a couple bends. But want you to look at the starter switch. The z looks to be rivoted on. While the 636 is bolt on. If I drill it out I. An bolt it but do not want to drill and it not be a rivot.lol also the brake master plastic cup is broken. Don't know where to get one
« Reply #15 on: August 21, 2012, 10:21:53 am »
Dam, if it ain't one thing it's another, but thats why ETB rocks
Re: z1000 636 swap
« Reply #16 on: August 23, 2012, 11:33:06 am »
Well got most together and found out since I'm using the 636 trees that I now had to order spacers for the wheel to fit right. Fml. Calipers came n and had new pads. Bout time something went good. Can't find the insert for master so I will have to make the original work for now. If I think about it later I will put some pics up to show
Re: z1000 636 swap
« Reply #17 on: August 24, 2012, 08:49:20 am »
Got the rest of my parts I hope.  ;D
Now we will see if it all works out today. If anyone decides route i am with the whole 636 swap ibcluding trees. U will need the 636 wheel spacers
Re: z1000 636 swap
« Reply #18 on: August 24, 2012, 09:53:43 am »
so you got it together???
Re: z1000 636 swap
« Reply #19 on: August 24, 2012, 02:57:41 pm »
Yeah. I will have to wait till I get home to post pics and what had to happen to make it work.
Re: z1000 636 swap
« Reply #20 on: September 04, 2012, 04:23:00 am »
OKAY,,, we are waiting on pics .....
 :30
Re: z1000 636 swap
« Reply #21 on: September 04, 2012, 07:45:53 am »
:lol
Re: z1000 636 swap
« Reply #22 on: September 04, 2012, 08:24:59 pm »
ok, so I been looking at fleabay and such for front end parts for my Z, I want to keep my handlebars sooo, that means I can just use 636 forks, calipers, and rotors? and master cylinder? I would like to avoid the clip-ons if possible, does that mean I have to come up with a way to mount the master cyl. and use custom length brake lines?.  Reason I ask is I may just start buying pieces here and there as I get the $ and as they are available, I found pretty good deals on some calipers and forks, not so much luck on the master cyl. though
Re: z1000 636 swap
« Reply #23 on: September 04, 2012, 10:36:14 pm »
Custom lines are unnecessary. you can use your lines. You don't have to change out your triples at all. Thus keeping your stock bars. You will need Forks, calipers, axle, spacers,
you can use your master cylinder. Although I would strongly recommend the 636 radial master. and steel braided brake lines. Also stick with all 05-06 636 arts as well. it will be a bit easier for what you are wanting to do. this will keep it all as just bolt up without having any modding. and any master cylinder on the 636 from 03-present will work.
Also I posted in the Parts Interchange list my Z Interchange parts list. May be helpful...
http://easttnbikers.com/forum/index.php?topic=2593.msg34091#msg34091
« Reply #24 on: September 04, 2012, 11:00:32 pm »
Thnx, and I seen the post too, hope to have all the parts soon to do the rebuild during the winter, gonna go ahead and get son calipers, found some 05 for 60, forks for 150
« Reply #25 on: September 06, 2012, 06:51:21 am »
Found forks,calipers,master cyl,rotors, all05/06, @ $550 on fleabay, all from cycle parts shops, is that a ok price?
« Reply #26 on: September 06, 2012, 06:54:47 am »
I take it that includes the front wheel too... if so not bad.
« Reply #27 on: September 06, 2012, 07:41:38 am »
No jeff, no wheel,all are from 2 different sellers, I've seen cheaper forks, these were 225, with complete tree, I'm sure I could find a better price w/just forks but these were pictured w/run-out gauge
« Reply #28 on: September 06, 2012, 08:20:39 am »
Craigslist has a set of forks right now for 120. No trees. Awesome deal. 05-06 model
« Reply #29 on: September 06, 2012, 08:26:12 am »
Yea Donald,i would rather be able to see if they are straight and not leaking if it's within d driving distance that would be nice
