Author Topic: z1000 636 swap  (Read 21962 times)
Re: Re: z1000 636 swap
« Reply #30 on: September 06, 2012, 08:49:39 am »
Yeah I think there in Knoxville. Hold on I'll check
« Reply #31 on: September 06, 2012, 08:52:08 am »
423-408-5411. He's located in kingsport
« Reply #32 on: September 06, 2012, 10:00:50 am »
Thanx, you go ahead and buy em for me;D just cause I'm such a nice guy
Sent from Cygnus X-1
Re: z1000 636 swap
« Reply #33 on: September 07, 2012, 07:44:24 pm »
right  would if i had it bro, just bought a new tire and still need front and chain and sprockets
« Reply #34 on: September 07, 2012, 08:27:27 pm »
I'm gonna pick up afront end tomorrow, and some stuff for jeff and midnight so I am no longer searching for forks!  YESSSSS! or mast. Cyl., or calipers
« Reply #35 on: September 07, 2012, 10:25:45 pm »
Sweet now you will be with me. I have Tue complete swap. I need to get the zx10 wheels now and was going to get the rear but funds are too short this week.>:(
Re: Re: Re: Re: z1000 636 swap
« Reply #36 on: September 08, 2012, 08:52:26 am »
Hey donald. What did you do with your stock z upper???  Could I borrow it here soon and if it works for what is needed ill buy it......
« Reply #37 on: September 08, 2012, 09:44:14 am »
At curts. Should be n that box or by it against the wall.
Re: z1000 636 swap
« Reply #38 on: September 09, 2012, 08:13:29 am »
i saw it there yesterday, im gonna see what it looks like with the plans i have.... thanks
« Reply #39 on: September 09, 2012, 09:20:41 am »
Anytime
Re: z1000 636 swap
« Reply #40 on: September 09, 2012, 02:10:10 pm »
if it works like i read it does then ill want it if you wanna part with it....
Re: z1000 636 swap
« Reply #41 on: September 09, 2012, 05:27:30 pm »
Help me find the spacers for a zx10 wheel swap and it is yours. Or someone that can make them with out breaking my pocket
Re: z1000 636 swap
« Reply #42 on: September 09, 2012, 05:41:49 pm »
Re: z1000 636 swap
« Reply #43 on: September 09, 2012, 05:53:17 pm »
That pic is what it looks like from the top with the swap. Also I was wrong on yer. These are the 03-04 636 forks and tripples.forks r the same as 05-06.
This is the wire from the 636 that holds the harness up.just bent it the way I wanted. It holds pretty good.
After install of the rear shock and a bath.also got my crg mirrors on.
Do have an issues with the clip one but will deal with for now. The way my headlight assembly has to sit put the clutch and brake levers right against my plastic. Doesn't affect my riding but has started wearing slots in it. Going to get some more clip one if I do not do what apex did to his stunt bike and put them backwards and on top of the triple.sry for the late post of these.
Oh and the 636 front wheel spacers didn't work there smaller then the z. So I improvised and used two triple washers one on each side of the wheel which has worked real well. Do have some vibration but my front tire is cupped. Get it changed and see if it goes away.
« Reply #44 on: September 10, 2012, 08:38:51 am »
Yea I told jeff that you used the triples off the 03-04. Jeff before you take everything apart on the bast that top clamp off the z will not work with the lower 03-04 zx clamp... I am telling that's why donald did not use his. Wouldn't work....
« Reply #45 on: September 10, 2012, 10:34:39 am »
Yeah. The swept from the two bikes are different. I had to use the 636 up n lower or go buy another lower. Wasn't going to happen.
Re: z1000 636 swap
« Reply #46 on: September 14, 2012, 09:33:31 pm »
so I'm gonna hop onboard this thread with my swap, I've got all my stuff now I think and should be starting the build over the weekend. Hope I don't run into too many snags. I will post a pic or two when I'm finished and maybe a couple of those "what do I do with this" pics during the swap. I'm soooo ready to have this done. I't's hard to take the bike out now with all those parts sitting on the table just begging to be put on. By the way does anyone know of a rearset i can put on without breaking the bank, Brad told me zx10 rearsets would work, I saw a thread on the streetfighter forum about that too, seems there was a little drilling/tapping involved, if anyone knows chime in  please
« Last Edit: September 14, 2012, 09:36:29 pm by tnzeder »
Re: z1000 636 swap
« Reply #47 on: September 15, 2012, 03:20:20 am »
 :nothing
« Reply #48 on: September 15, 2012, 08:10:48 am »
man I have no clue on that.  If you find anything out post it so I will know. I want different ones my self
Offline Trav-A$$
  • Track or Street.... It's still riding!!!
Re: z1000 636 swap
« Reply #49 on: September 15, 2012, 10:52:38 am »
Your welcome to try hese 636 rearsets...
Track Addict....
Offline Trav-A$$
Re: z1000 636 swap
« Reply #50 on: September 15, 2012, 10:54:21 am »
I prob have the spacers....  I have alot for front and rear off of different things
Track Addict....
« Reply #51 on: September 15, 2012, 11:10:40 am »
Hmm, thanks Trav, not sure if they work or not but can try, I hope to hook up with you in the next couple days to grab that damper. I'll be in touch
« Reply #52 on: September 15, 2012, 02:36:12 pm »
ill see what I find out. Not sure if the 10 spacers will sufficient or if I still need more. I know my front z wheel is smaller width wise vs the 03-04 636. Had use two tree washers to get it to work. I'll let u know in a bit
« Reply #53 on: September 15, 2012, 02:43:29 pm »
Ok so according to the swap charts, since I am using my stock Z triples,i shouldn't have an issue with the wheel spacers right?
« Reply #54 on: September 15, 2012, 05:19:47 pm »
Right. The only time it would be an issue is if u change wheels or do like I did and change the tripples
« Reply #55 on: September 15, 2012, 05:21:02 pm »
Also new to come. I making the z full carbon fiber with out the cost :)  stuff is ordered and im going with black and white. I think it will look sic
« Reply #56 on: September 15, 2012, 06:04:18 pm »
Vinyl wrap? I thought about that before, anxious to se what it looks like
« Reply #57 on: September 15, 2012, 07:44:32 pm »
Yea. There's a guy on the zx6r forum that has done it and has turned out amazing. So I'm going to but want to break up Tue black with some white
Re: z1000 636 swap
« Reply #58 on: September 15, 2012, 09:38:15 pm »
here is the link to a ZX10 rearset job I was looking at http://www.customfighters.com/forums/showthread.php?t=31474
Re: z1000 636 swap
« Reply #59 on: September 16, 2012, 09:12:16 pm »
Talk about a holy s**t moment....look what I found after removing my headlight cover/lights
there is a gouged out place on my fork where my HID ballast has been rubbing against my forks, another year of that and catastrophic failure.  It seems my ballasts barely fit in there and I didn't realize there was that much friction between the ballasts and forks, I will be wrapping the ballasts in rubber or something before putting everything back together with the other forks. This is a big friggin  :groan
