Author Topic: z1000 636 swap  (Read 21180 times)
Re: Re: z1000 636 swap
« Reply #60 on: September 17, 2012, 08:06:25 am »
Lol. Well at least u cought it
« Reply #61 on: September 17, 2012, 08:08:43 am »
:27 holy crap. That is not a good thing at all.
« Reply #62 on: September 19, 2012, 09:50:07 am »
Since I have swapped my rear shock for aZX-6 shock, shouldn't I take my Z1000 spring and put it on the ZX6 shock? So far the ZX spring feels ok but isn't the Z shock rated for a heavier load?
Sent from Cygnus X-1
Re: z1000 636 swap
« Reply #63 on: September 19, 2012, 01:43:40 pm »
dont, just have the suspension set up for you when you get the front done. my 06 z1000 had the 636 rear shock and was easily capable of the weight of the bike and me...
« Reply #64 on: September 19, 2012, 02:26:46 pm »
Cool, thanx Jeff, yea I'm gonna take her up to Wheelers when I get it all back together
« Reply #65 on: September 19, 2012, 04:33:36 pm »
I need to as soon as I have the extra $ and the new front tire on I will
Re: z1000 636 swap
« Reply #66 on: September 19, 2012, 04:45:23 pm »
ill probably be putting the new front on the bastard tonight if i feel up to it after work...
« Reply #67 on: September 19, 2012, 06:37:12 pm »
Woohoo!
Re: z1000 636 swap
« Reply #68 on: September 19, 2012, 07:31:03 pm »
Woohoo!
i was refering to the tire, lol..... still need a few parts before i start on the swap....
Re: z1000 636 swap
« Reply #69 on: September 19, 2012, 08:32:12 pm »
lol, ok Jeff , so I'm sitting here looking at your post and watching tv at the same time, as my finger accidently slides across the pressure pad on my laptop I look down at the screen and voila! I have smited thee! I think maybe twice, flmao, so I then try and applaud you back twice, and it only lets me do it once, hillarious, so sorry it was accidental smites :21
« Reply #70 on: September 19, 2012, 09:55:34 pm »
Lol
Re: Re: Re: z1000 636 swap
« Reply #71 on: September 20, 2012, 09:06:32 am »
Ohhhh you sorry sack of monkey spunk!!!  Hahahahaha lmao j/k.
« Reply #72 on: September 25, 2012, 01:55:04 pm »
Getting it back together,sorta, having problems getting calipers/wheel lined up, I know forks are good, 03', calipers not sure what year, have 10mil bolt spacers so no problem there. I'm using Z wheel and those 280mm rotors, maybe they are ZX10?, anyway they are 1mm thinner and the calipers aren't scrubbing so bad (pads)? Now just trial and error adding washers I.e. fabricating correct wheel collar thickness to add to my Z collars,Zx collars are way too narrow, seems better to just add to the Z collar, gonna try 2 on each side (should be about 5 mil)  Donald I understand you had to do something similar with the wheel spacer issue?
« Reply #73 on: September 25, 2012, 03:31:00 pm »
Yeah. I actually took two washers from the top triple lock down nut and put on each side. Little pain to get the axle n but they work good.
Re: z1000 636 swap
« Reply #74 on: September 26, 2012, 01:04:44 pm »
you are using z1000 triples with the stock front wheel and rotors right?? confirm with curt but i believe he just used the stock z1000 spacers and that was it. also if you are using the z1000 rotors, they are 300mm, not 280.
donalds swap is not gonna do much good for you on the spacers, he swapped all the triples and everything.
« Reply #75 on: September 26, 2012, 02:07:44 pm »
I typoed the rotors wrong, both sets are 300, tell me this, if I use the z spacers alone there is some play, the wheel slides back and forth a little, didn't think that was normal, maybe an eigth
Re: z1000 636 swap
« Reply #76 on: September 26, 2012, 02:20:42 pm »
like i said, check with curt. he did his swap same as you with the z triples. it may be you have to use the 636 spacers. i cant remember 100% wich way it was....
Re: z1000 636 swap
« Reply #77 on: September 26, 2012, 04:39:20 pm »
Thanks for the help guys, I never done a fork swap before so it's a good learnign experience, I have the final part ordered now I think, 00-02 zx6 spacers, I think the fabricated ones I have will do the job but I will replace with the 02zx6 ones when I get them. However, the last couple days have been up and down or I would have been riding by now, hope to be by the 7th, my vaca. starts then and I dont have enough back tire for the mtns. right now anyway. continued on another thread (family health issues)
« Reply #78 on: September 26, 2012, 06:56:56 pm »
I tried the 03 -04 with mine and they were even smaller then my z
« Reply #79 on: September 26, 2012, 07:07:19 pm »
Sorry your having trouble. No sure why. Unless the 03-04 z's have a bit different triple clamp than the 05-06. Kind of odd. I just used the zx6 spacers on my setup. But now the front end I had was an 05-06 zx6 setup. So its possible the 03-04 zx6 is a bit different? I got your txt but been under the weather. I will try and give you a shout tomorrow.
« Reply #80 on: September 26, 2012, 07:14:05 pm »
I saw a pic of the 02 zx6 spacers, someone has used them on a swap just like mine, they are wider than my z spacers,I think the differences lie in the fork legs from 03-06 being different thickness along with wheel hub differences maybe, either way it's just a matter of time for me, can't ride too hard anyway til I get new back tire
« Reply #81 on: September 26, 2012, 08:46:55 pm »
Update--re-installed my axle spacers with added pair washers, along with my Z rotors, my left caliper has a little drag due to a slightly off square cut of the caliper spacer, easy fix. Now to add brake lines, things are looking up
Offline Trav-A$$
  • Track or Street.... It's still riding!!!
Re: z1000 636 swap
« Reply #82 on: September 26, 2012, 09:11:17 pm »
I have spacers for an 02
Track Addict....
« Reply #83 on: September 26, 2012, 09:36:12 pm »
Hey Trav!, we gotta go ridin,I'm off next monday, hope to have this beast running by the weekend, may ride out your way then, still need to round up that damper, cheers
« Reply #84 on: September 28, 2012, 12:13:48 am »
More progress reservoir placed tomorrow will fill/bleed brakes. did the best I could do with bare minimum length lines, got these carbolines with the fork purchase so I'm using them may get longer dual s/s lines later on. Hope to test drive tomorrow night, (fingers crossed)
« Reply #85 on: September 28, 2012, 10:13:07 am »
Looking good. Wish I had ur master cylinder n Res. Looks a lot better
« Reply #86 on: September 28, 2012, 10:56:38 am »
Thnx Donald, Mot. Superstore had the oem style res for $26 new, same thing as the crappy used ones on ebay and they want $30-40 They also have a radial mc/res package deal for pretty good price , might wanna check it out before you pay big bucks for a used one
« Reply #87 on: September 28, 2012, 04:42:52 pm »
I will. Have one from a 03-04 but need the elbow and it has a cracked spot that's missing right there. Need to install n see if it leaks r not
Re: z1000 636 swap
« Reply #88 on: September 29, 2012, 07:48:30 pm »
 ;D ;D ;D Test Ride............... :18 :& :13 :like ok so everything I've heard about the swap is true...now I gotta re-introduce myself to this Z, it is truely a different bike
« Reply #89 on: September 29, 2012, 08:04:44 pm »
Oh yeah it is. Be careful till you get her broke in :)
