Author Topic: Oil pan Helicoil kit  (Read 1200 times)
« on: August 10, 2013, 10:00:52 pm »
Anybody have one I could borrow/buy? Years ago I stripped the oil pan on my bike. I've been able to limp it along but the time has come to actually fix it but don't want to have to replace the whole pan. I'm pretty sure it's a M12x1.5...
Whatcha got?
Re: Re: Oil pan Helicoil kit
« Reply #1 on: August 10, 2013, 11:24:14 pm »
Autozone sells that size
adrenaline rushing speed demon. insane? yes!!
« Reply #2 on: August 11, 2013, 07:23:40 am »
Whatcha got?
Yea we do carry that size in stock you should be able to pick it up at any autozone near you......if you cant find it let me know and ill pick one up for you
Sent from my iPad using Tapatalk HD
« Reply #3 on: August 11, 2013, 08:01:33 am »
If you are going to heli-coil it you can make it any size you want that is in that range.
Offline Full Tilt Boogie
« Reply #4 on: August 21, 2013, 10:08:29 pm »
I a few weeks ago took  gsxr pan that had the same issue and took a piece of.1inch round.stock, machined it.completely flat and welded it.over the factory plug hole. drilled and tapped it. no way it will ever strip.
