Author Topic: 12pt 5mm needed desperately..  (Read 3064 times)
« on: January 02, 2014, 06:42:21 pm »
12pt 5mm needed desperately... As in the type that is like an allen but has 12pts instead of just 6 of them....
Advance wants to only sell you the whole kit for 80bucks...
Stinking VW water pump! :banghead
« Reply #1 on: January 02, 2014, 07:10:09 pm »
I looked but I don't have any 5mm triple square bits.
Offline Chris_T
Re: 12pt 5mm needed desperately..
« Reply #2 on: January 02, 2014, 07:12:03 pm »
you mean one of these?
« Reply #3 on: January 02, 2014, 09:10:27 pm »
Thanks for checking but it was a six and it promptly stripped out when trying to take out the bolts...
« Reply #4 on: January 02, 2014, 09:15:47 pm »
most likely gonna be a dealer only part or see if a VW tech has one you can borrow.
I hate it when they require custom tools, Most likely only ever need it once..
« Reply #5 on: January 02, 2014, 09:19:27 pm »
Yep 8,10,and 12 are the only ones I know of I can get.
« Reply #6 on: January 02, 2014, 10:48:04 pm »
Advance Auto had a set but it didn't help. :banghead
« Reply #7 on: January 02, 2014, 10:52:20 pm »
From the pic you posted I'd say your down to either trying to get it to turn with a chisel or drilling it out.
« Reply #8 on: January 03, 2014, 03:04:28 am »
what in the world have you got into. 5mm 12 point ? just that a flat screwdriver & file/grind to fit across to cuts , there can't be that much torgue on a 5mm.
« Reply #9 on: January 03, 2014, 08:02:50 am »
unless its threaded into an aluminum block.  They love to corrode and stick.. or break.
Offline bigshoes65
« Reply #10 on: January 03, 2014, 11:08:27 am »
will check at work tommor . off today . i do have a set of vw  12 point sockets. working saturdays
« Reply #11 on: January 03, 2014, 05:42:58 pm »
Ok, guys, thanks for all the repsonses :22
It turns out it was what is called a "Triple Square" bolt...three of them, and of course they all stripped out.  :banghead
I was able to drop the sub-frame of the car the get the motor to drop enough to get a drill on the bolts.  :groan
8 hours later and $1 worth of replacement bolts, the car is back on the road. :happypep
« Reply #12 on: January 03, 2014, 05:47:24 pm »
« Reply #13 on: January 03, 2014, 07:18:07 pm »
Wow.  Gotta love engineering genius.  At times I would love to shoot the designers.
Offline Chris_T
« Reply #14 on: January 03, 2014, 07:54:08 pm »
I've tried to get my company to send the designers out and make them help us set-up a few machines. Told my big boss that if he'd do that then the designers would make **** easier to service.
hasn't happened yet.
« Reply #15 on: January 03, 2014, 08:12:05 pm »
Funny how manufacturing cost always is the most important.Secondary cost be damed.
Offline Chris_T
« Reply #16 on: January 03, 2014, 08:28:28 pm »
to be honest, this is EXACTLY how we wound up with front wheel drive. not that its safer or better, but that its cheaper and easier to manufacture.
« Reply #17 on: January 03, 2014, 08:55:27 pm »
Yep thats how all the new improved stuff gets here.
Offline bigshoes65
« Reply #18 on: January 05, 2014, 12:03:05 pm »
did have a six mm. but i see you got it.
