Author Topic: TTR125L caliper pin  (Read 3682 times)
TTR125L caliper pin
« on: April 23, 2014, 04:32:24 pm »
The anchor/pivot pin is seized in the caliper. Suggestions??
Offline bigshoes65
Re: TTR125L caliper pin
« Reply #1 on: April 23, 2014, 04:45:18 pm »
same issue with cars . moderate heat . tap on housing around pin. if you are not worried about  marks from hammer. you can always sand hammer marks and paint caliper. sucks it aluminum.
« Reply #2 on: April 23, 2014, 04:57:23 pm »
Hose it with some on blaster while it hot.
« Reply #3 on: April 23, 2014, 06:13:22 pm »
I've got a heat gun if you need to borrow it. Be a little easier on the paint than a torch.
« Reply #4 on: April 23, 2014, 07:49:24 pm »
I'm not too concerned with the paint. It's the seals if Iover do it that concern me.
« Reply #5 on: April 23, 2014, 08:22:55 pm »
Just shoot me a text if you want to try it. I'll be home tomorrow evening.
« Reply #6 on: April 24, 2014, 03:08:28 am »
« Reply #7 on: April 24, 2014, 02:42:27 pm »
be sure to apply high temp bearing grease when you put it back together..
Some steel and aluminum just don't like to weather together..
good luck..
If it will move at all just keep working it back n forth, don't force it if possible..  generous amouts of lube or rust remover to help break up the oxidation..
« Reply #8 on: April 24, 2014, 04:40:37 pm »
good luck..
It won't budge... I guess I'll let it soak a bit longer. And, if need be heat it.
« Reply #9 on: April 24, 2014, 04:58:31 pm »
You can also whack it with hammer.
« Reply #10 on: April 24, 2014, 05:43:47 pm »
or my favorite persuader a air hammer....   on low pressure usually frees up rusty shafts on mowers, wheels, pulleys...
« Reply #11 on: April 24, 2014, 05:49:27 pm »
Yup, don't force nothing, use a bigger hammer.
« Reply #12 on: April 24, 2014, 06:49:32 pm »
Ah, c'mon guys... I just mean to seat the allen wrench a little better  ;D
« Reply #13 on: April 24, 2014, 07:28:01 pm »
You can seat an Allen wrench pretty damn well with a ten pound hammer.  :31
« Reply #14 on: April 24, 2014, 07:51:00 pm »
 :21  :lol
« Reply #15 on: April 24, 2014, 08:16:54 pm »
You can seat an Allen wrench pretty darn well with a ten pound hammer.  :31
Also good for recycling beer cans..   LOL
« Reply #16 on: April 24, 2014, 09:07:41 pm »
The bolt you put through the caliper came out fine. It's the one that screws into the mount that you slide the caliper onto that is froze. Frankly I considered drilling a small hole to gain access to the head of it.
« Reply #17 on: April 24, 2014, 09:15:39 pm »
You could do that, then tap it and plug a small bolt/screw into it in case it happens again.
The bolt/screw would not only keep weather out but reinforce the weak point in the casing caused by drilling it.
But hey, what do I know, I'm just an ignorant hillbilly.
« Reply #18 on: April 25, 2014, 03:08:31 am »
That's kinda what I was thinking too.
« Reply #19 on: May 01, 2014, 04:27:05 pm »
Well I put penetrating oil on it several times over the last week or so with no success. So I heated it also with no success. I decided to drill a hole and use an Allen wrench to twist the pin loose. I bolted the bracket back to the bike since I don't have a vise. Guess what happened...I broke pin end off the bracket. So I guess I gotta find a new bracket, pin, and might as well get the caliper too since I've yet to budge it.  :banghead
« Reply #20 on: May 01, 2014, 04:30:44 pm »
Bud, bring it by the Beauchamp Estate, we'll get'er out.
« Last Edit: May 01, 2014, 04:31:33 pm by r6boater »
« Reply #21 on: May 01, 2014, 04:36:22 pm »
Ok, I'll give you a shout when we get finished with dinner. Thanks! Any chance you got a bracket laying around? lol
« Reply #22 on: May 01, 2014, 04:47:48 pm »
No, sorry, no bracket...
Talk atcha soon.
« Reply #23 on: May 01, 2014, 07:12:13 pm »
Thanks for the help Kurt.  :21
« Reply #24 on: May 01, 2014, 08:08:00 pm »
No problem! :21
