Author Topic: triumph Bonneville Scrambler mods  (Read 2733 times)
Offline LuckyPuck
  • Bike whore extraordinaire
  • Woof!
« on: January 13, 2015, 11:19:02 am »
figured i've been doing so many mods to my Triumph it needed its own thread.
I started off with a 2013 Triumph Scrambler that I bought new a year ago as of November. While it is a very nice bike it does have some shortcomings when stock namely bad suspension, heavy sewing machine sounding exhaust, terrible mapping causing throttle issues and an abundance of excess pork.
When i bought the bike i removed the AI and drilled the baffles the next day. It remained in this configuration with the exception of some exhaust wrap to combat the excessive heat from the exhaust. I believe this issue was partially due to the lean tune from the factory.
I ended up putting 1500 miles on it this way and was actually considering selling it since my GS gets all the miles.
Since I had some time off from riding due to my less than graceful way of walking out my front door resulted in a broken leg i decided i might as well improve some of the bikes issues.
I started by removing the mufflers and replacing them with a set of Baffled Empi exhaust tips from a VW bug. The O.D. on the VW tips is a perfect fit on the scrambler and even uses the stock gaskets and clamps.
After this I added a set of Tecbike shocks.
Next up  was to remove the passenger pegs and sprocket cover and replace it with a lightweight billet cover.
At the same time i also added a handlebar crossbar to cut down on the flex of the higher bars.
The fun part was using TUNEECU to download a new map. I havent been able to ride it yet but it runs much better at idle and has better throttle response.
This weekend i will be taking the stock round tailight and plastic signals off and replacing them with lucas style aluminum bodied pieces.  These arent as light as the stock pieces but are definitely sturdier.
First picture shows the stock bike.
« Last Edit: January 13, 2015, 01:06:21 pm by LuckyPuck »
BULTACO M49 Sherpa T 250
DRZ-400S
DRZ-400SM
Concours14
Offline LuckyPuck
  • Woof!
Re: triumph Bonneville Scrambler mods
« Reply #1 on: January 13, 2015, 11:25:56 am »
I also picked up one of these helmets (Biltwell Gringo)
but mine has the half smoke shield that shows the chinbar better. Once i receive it it will get some pinstriping work done on it by a friend of mine.
DRZ-400S
DRZ-400SM
Concours14
« Reply #2 on: January 13, 2015, 12:56:49 pm »
Very nice.
« Reply #3 on: January 14, 2015, 04:10:34 am »
Looks like a NASA helmet...I like it.  :21
« Reply #4 on: January 14, 2015, 06:55:33 am »
Under the visor it looks like an early Bell Star.
« Reply #5 on: January 14, 2015, 07:55:02 am »
There are a few things that I don't like about my Shadow. The exhaust is too loud and a few other things. I was looking for an exact match stock exhaust without much luck. I think that I will start looking around for other parts that I may be able to make work. You have motivated me to step outside the box.
Offline LuckyPuck
  • Woof!
« Reply #6 on: January 14, 2015, 08:59:49 am »
Either a Bell or Buco I'm sure was the inspiration.    Bell makes the Bullit which is probably closer to the old Star but they really missed the mark with a $400 price tag...
DRZ-400S
DRZ-400SM
Concours14
Offline LuckyPuck
  • Woof!
« Reply #7 on: January 30, 2015, 06:20:46 pm »
And she'd back ready for the road About 40# lighter.
DRZ-400S
DRZ-400SM
Concours14
« Reply #8 on: January 30, 2015, 07:40:57 pm »
Tell me more about the shocks!
Offline LuckyPuck
  • Woof!
« Reply #9 on: January 30, 2015, 08:25:43 pm »
I got them from TEC BIKE. Not the best but worlds better than the factory ones. They had decent reviews on the Triumph forums. For about $150 it was well worth it,  i dont ride it enough to justify OHLINS or even Hagon but these do the job, now my BMW has Ohlins but I ride that 10x as much...
All the mods its a TOTALLY different bike Thats a blast to ride.
« Last Edit: January 30, 2015, 08:27:48 pm by LuckyPuck »
DRZ-400S
DRZ-400SM
Concours14
« Reply #10 on: January 30, 2015, 11:42:53 pm »
They look like the RFY's on my bike.  If they are the same (most of the Chinese products come from a limited number of factories), Check the N2 pressure and the oil.  The oil you can probably only cycle the suspension and listen for air bleed sounds.  The good news is that they are really decent if rebuilt...and filled with oil properly.  N2 pressure should be around 75 psi.
Here is a thread I posted on how to rebuild them, on a vintage performance forum.
http://www.caferacer.net/forum/tips-tricks/24204-rebuilding-rfy-cheap-shocks.html#post313752
Offline LuckyPuck
  • Woof!
« Reply #11 on: January 31, 2015, 06:58:01 am »
They are similar to the RFY's, some people have compared them directly and there are some differences outside and in the internals.  They do say that quality control and assembly that these are a step up from the RFY's. I was going to go for the RFY's but these weren't much more and the reviews I could find were better.
« Last Edit: January 31, 2015, 07:05:36 am by LuckyPuck »
DRZ-400S
DRZ-400SM
Concours14
Offline LuckyPuck
  • Woof!
« Reply #12 on: February 09, 2015, 12:41:20 pm »
Finally got to put some miles on the scrambler this weekend.
Its a bit loud..lol though dogs dont bark and chase it they just look confused.
It's a COMPLETELY different bike now, seriously its Jeky'll and Hyde.  It really reminds me of the 640 Duke I had just without the lean angles.   It'll pull power wheelies now and is much better at jumping railroad tracks and drifting corners, in general hooligan behavior.
From sewing machine to teabag sucking Harley slayer..
DRZ-400S
DRZ-400SM
Concours14
