Author Topic: BMW R1200RS first road test  (Read 1934 times)
« on: August 22, 2015, 06:32:52 pm »
seen on the Motorcycle.com website at: http://www.motorcycle.com/manufacturer/bmw/2015-bmw-r1200rs-first-ride-review.html
2015 BMW R1200RS First Ride Review
By John Burns
July 7, 2015
Photos by: Kevin Wing
2015 BMW R1200RS
Editor Score: 90.25%
Engine   19.0/20
Suspension/Handling   13.5/15
Transmission/Clutch   8.5/10
Brakes   9.25/10
Instruments/Controls   4.25/5
Ergonomics/Comfort   9.25/10
Appearance/Quality   8.5/10
Desirability   9.0/10
Value   9.0/10
Overall Score   90.25/100
On Day 2 of our little press junket to Ontario, the sun came out, the birds sang, and we rode the new 160-horsepower BMW S1000XR ítil hell wouldnít have it anymore. Okay, fine, we rode only ítil cocktail hour. On Day 1, though, it rained all day, the mosquitoes made the air hum at every stop, the roads were treacherous and I was very glad to be on the new R1200RS instead.
If the new XR is a pair of stiletto-heeled red pumps, the new RS is way closer to being your favorite pair of trusted hiking boots. Both bikes now sport advanced electronics that make them nearly foolproof even in sloppy conditions, but for me anyway, thereís something about BMWís classic Boxer Twin thatís as comforting and reassuring as a home-thawed meal. Maybe itís because I remember being at the launch of the first oil-head R1100RS a mere 22 years ago.
Though not without their faults (most of which have been cured now that the clutch has been moved to the front of the engine), these things have served us well over the millennia as tourers, sport-tourers and sportbikes, long before we dreamed BMW would ever build anything like the K1600 or S1000RR. The beloved Boxer is what will always pop into my brain when somebody says BMW. There are motorcycles you have a fling with for a couple years who then trade you in for a better rider. Then there are motorcycles you establish a trusting, long-term relationship with. This BMW is one of the latter. The flat-Twin Boxer engine on the new R1200RS is the same DOHC unit that already powers the R1200GS, R1200RT and the new R1200R. BMW claims 125 horsepower at 7750 rpm and 92 lb-ft of torque at 6500 rpm (which worked out to 108.7 rear-wheel hp at 7800 and 77.6 lb-ft at 6600 rpm on the 2015 R1200GS Adventure we dynoed here.) Compared to the engines on the GS, GS Adventure and RT, BMW says the RT should have a bit more low-rev torque thanks to a different airbox.
And with these bikes, itís all about the torque. If the RS doesnít have the 160-hp, 11,000-rpm top end of the XR, BMW says the 1170cc Twin at least makes 9 more lb-ft of torque, 92 lb-ft at 6500 rpm instead of the XRís 83 at 9250. For some reason, the RS feels considerably more substantial at first sit than the XR (must be those two cylinders jutting out), but BMW says the RS is only 18 pounds heavier Ė 520 to 502. So even though the XR feels way sportier and more hyperactive, the reality is that the RS can probably match it step for step right up to a speed beyond which you should never ride on the public roads anyway. Maybe even down dirt roads, too, since the RS has almost as much suspension travel as the XR Ė 5.5 inches versus 5.9 at both ends (under a seat whose standard height is 0.8-inch lower, at 32.3 inches).
Itís called a Boxer, kids, because the pistons move in and out together, like a boxer jabbing his fists outward to warm up. On the road, it produces the reassuring drone of a trusty aircraft engine.
The new RT is very much like the new R1200R I got to sample last December (when it also rained), the most obvious difference being the addition of a half fairing. Early RS drawings looked a little top-heavy/buxom, but the final design looks really proportional to my eye, and nicely downplays the downdraft intake tracts of the new Boxer that are a little too prominent on the naked, R version.
The windshieldís in low here, but snaps up a few inches into a high position. Its design, and that of the fairing and its winglets, produce nice, smooth airflow in either position.
Instead of the naked bikeís handlebar, the RS gets a pair of clip-ons stuck into a tricky forged deal attached to the top clamp, and instead of the Rís sit-up-straight ergonomics, the RS pulls its rider an inch or two forward and lower into the cockpit, though the footpegs and delicious seat feel like theyíre in the same place as before. Where the R is aimed slightly more at urban use, the RS is designed to also serve as an all-weather long-range sport-tourer, to cross over into R1200RT territory.
Originally, the R and RS were supposed to be the same bike, one faired and one not Ė but BMW canít ever seem to take the easy route. Specs indicate the RS is 0.5 inch longer of wheelbase, with 0.4-inch less trail than the R, which should give it plenty of high-speed stability along with slightly quicker steering than the R if youíre a he-man willing to leverage its narrower handlebars. (All the manufacturers worry about your body becoming a high-speed source of instability on their naked bikes.) I can vouch for the stability of both of them at medium speeds anyway. Most Boxers feel like they could ghost ride the length of I-70 if you set the cruise control and jumped off.
The base version, which is slated to sell for $14,950, comes with BMWís Automatic Stability Control, and Rain and Road modes. Youíll need to step up to the Standard package ($16,025) to get the heated grips and cruise control (where I could probably stop). If you want the Dynamic Electronic Suspension Adjustment (ESA), youíll be signing a $17,770 check. Itís hard to say if the ESA is worth it on this bike, since nobodyís ever seen or ridden the non-ESA one (which is supposed to have a remote preload adjuster and rebound-adjustable shock out back). Shift Assist Pro is a thing I could easily do without on a bike like this one; itís kind of jerky at low rpm, and low- and mid-rpm is where you ride these bikes most of the time. The six-speed gearbox on every one of these Iíve ridden shifts perfectly without the clutch, up or down, if you roll out of the throttle just the tiniest bit, as God intended, and nudge the lever.
No more Telelever. The need for a bigger radiator after the switch to liquid cooling provided the necessary excuse to switch to a conventional fork.
Something in a nice gray and black, perhaps? I could pop the screen to high (itís low here) if I set the cruise control and used both hands. That seatís nice and thick; higher and lower options are available.
Ride Modes Pro is the other big deal with the Premium package, which gets you Dynamic and customizable User ride modes in addition to Rain and Road, along with Onboard Computer Pro, which allows you to configure the TFT instrument display in various ways to suit your mood. Ho hum Ö Youíre supposed to be able to get Ride Modes Pro as a $350 option on any RS, which is definitely the way to go since with it comes Dynamic Traction Control Ė a great thing to have in the rain. All RSís come with switch-offable integral ABS brakes.
Anyway, I wanted all the electronic help I could get in the Canadian slop, and the RS was there for me, complete with two-position heated grips to keep my hands warm (with their own dedicated button), even as the water was making its way up my sleeves by the end of the day (other than that, my Gore-Tex-lined Dainese ensemble proved watertight yet again. Miraculous!).
Grabbing big handfuls of torque in the wet while leaned over results in nothing more alarming than a flashing light on the customizable dashboard, and on the new bike, a quick-turn throttle lets you get to full power with less wristation. Otherwise you just hunker down behind the reasonably generous windshield and get on with it; another advantage of RS over XR for the cheap at heart is that BMW says itíll get 57 mpg (at a steady 55 mph) versus 44 for the XR. Thatíll add up at $4 a gallon for premium.
Okay, yeah, the new S1000XR was the star of the show up there in the Great White North, and as I wrote last week it may be my favorite new BMW. But if Iíd had to pick it or the RS to ride back to SoCal from up there in the rain, and live with for the next year or two, Iíd have a hard time not climbing aboard the deep-dish, low-stress RS. Something about the old Boxer soothes the soul; itís probably no coincidence Pirsigís classic (and interminable) Zen and the Art of Motorcycle Maintenance is all about the Boxer.
+ Highs
Yo, itís the Harley-Davidson of Deutschland (but besser)
One of motorcyclingís all-time great engines; maintain it yourself
No-stress, smooth operator
\ Sighs
Not the prettiest RS ever
Instrumentation is a bit busy and small of digit
The new S1000XR is calling our nameÖ
It doesnít get the lean-sensitive ABS Pro brakes of the new XR, but BMWís Integral ABS, complete with 320mm discs up front and radial calipers, stops the RS with great power and confidence.
For a solo rider, the RS (with bags) will do everything the R1200RT will do. For most of us, itíll do everything weíd reasonably ask of the R1200GS (while being five pounds lighter) Ė and itís not at all far removed from the basic standard R1200R, which is one of the best motorcycles for doing absolutely everything else, ever devised. In our profession here at MO, itís sort of our job to fall for pretty new faces. But the older we get, the more we appreciate true love. Sniff.
2015 BMW R1200RS Specifications
MSRP:   base: $14,950, Standard: $16,025, Premium: $17,770
Type   :  1170 cc liquid-cooled Boxer Twin
Fuel System:   EFI
Ignition:   Electronic
Valve Train:   DOHC, 4v/ cyl.
Horsepower: (claimed)   125 @ 7750 rpm
Torque: (claimed)   92 lb-ft @ 6500 rpm
Transmission/ Final drive:   6-speed/ shaft
Front Suspension:   45mm inverted fork; 5.5-in travel; Dynamic ESA (Electronic Suspension Adjustment) optional
Rear Suspension:   Single shock; adjustable rebound damping and remote preload adjustment; 5.5-in travel; Dynamic ESA optional
Front Brake:   Dual 320mm discs; 4-piston calipers, part-integral ABS (can be switched off)
Rear Brake:   276mm disc; 2-piston caliper, ABS
Front Tire:   120/70ZR-17 radial
Rear Tire:   180/55ZR-17 radial
Wheelbase:   60.2 in.
Rake/trail:   27.7 deg./ 4.5 in. (114mm)
Seat Height:   32. in., Standard.
Curb Weight: (per BMW)   520 lb.
Fuel Capacity:   4.7 gal.
Tested Fuel Economy:   NA (BMW claims 57 mpg @ 56 mph)
Available Colors:   Racing Red, Light White
Warranty:   24 months
« Last Edit: August 22, 2015, 06:38:55 pm by Chris »
Re: BMW R1200RS first road test
« Reply #1 on: August 24, 2015, 10:22:34 am »
I like it.
 :whistle
« Reply #2 on: August 24, 2015, 02:03:43 pm »
I like it.
 :whistle
Me too.  I particularly like the seating position (see photo #1) which is very neutral and should be all day comfy even cooking along at a pretty good clip.
« Reply #3 on: August 24, 2015, 09:38:27 pm »
« Reply #4 on: January 27, 2016, 01:20:09 pm »
Pretty good video road test by RevZilla:
Ian:  Any thoughts?
« Last Edit: January 27, 2016, 01:21:09 pm by Chris »
« Reply #5 on: January 31, 2016, 04:25:52 pm »
I'm with the guy doing the review. An extra 1k for bags that should come standard. I did a build your own thing on their website and ended up with a nicely equipped model at $21.5k Pretty spendy at first glance but when you consider that was equipped with what I would like out of a touring bike, some crash protection and a couple sport accessories, it's a bit more bearable. Pretty much 21k for a do everything bike.
« Reply #6 on: February 06, 2016, 06:22:53 pm »
Somehow my picks came out to just a smidgen under $20K
« Reply #7 on: February 06, 2016, 07:54:57 pm »
I opted for the gps.
Sent from my SAMSUNG-SM-G870A using Tapatalk
