Author Topic: How to "Not To Get Your Money's Worth from Air Filter" (Burgman 400 Scooter)  (Read 822 times)
Air Filter used for 42,138 miles, 37,138 miles of that by your's truly. It's all Jackie's fault -- takes me on all those gravel roads. Maybe the problem is "I Mostly Just Ride."  :happypep
I got my Monies Worth, but I say, It Is Not The Way  To Get Your  Monies Worth.
PICTURES:
Anyone need a used Air Cleaner CHEAP  ???
The whole compartment where the air cleaner is located was pretty dirty.
Wow Paul, you should check that every 10k or less.
 :ditto lO
Good Sound Advice ---- However, it was running OK.  :o
