Author Topic: coil pacts  (Read 553 times)
coil pacts
« on: January 28, 2017, 01:37:41 am »
my 95 olds with 80xxx on it ,cuts out & misses when it's wet . so hit it with wd 40 & it goes on?? any help here ?? :groan
Re: coil pacts
« Reply #1 on: January 28, 2017, 02:22:54 pm »
What engine?
Sent from my SAMSUNG-SM-G870A using Tapatalk
Re: coil pacts
« Reply #2 on: January 29, 2017, 01:28:27 am »
3.5 of something . v6   something .it's the one gm put in every thing ?? :groan
Re: coil pacts
« Reply #3 on: January 29, 2017, 02:44:51 am »
Should be an ignition control module under the coils then. You can take it off and have it tested at any auto parts place.
Re: coil pacts
« Reply #4 on: January 29, 2017, 08:46:52 am »
 think GM standard was a 3.6L.
Good idea Ian -- did not know one could do that. Auto Parts Test.
Kind of got the impression that it's intermittent (depends on moisture). Might not show up in a test.
Not that I am an expert on cars or car repairs, been lucky over the years on a few fixes.
I use to try a lot, cause I don't trust shops - seems like a lot rip you off and even honest ones cost you a fortune at $80 an hour labor.
